'94 Merc Sable (130K miles), won't start, won't crank. The owner replaced the starter and ignition relay (I think, it was in the steering colum), still no start.
If the key is turned to start, and the starter motor is jumped, the engine will start and run fine. The battery has been replaced.
I know, this guy has been throwing parts at it. I sold him the car, so I figured I'd ask the experts here for a little advice. From what I've been able to figure out, this could be a grounding issue, or the control module above the radiator. Yes/No? Is there a way to check the control module with a meter?
One more point, for a while, this was an intermittant problem, which seemed to clear up after fiddling with the battery cables. However we've checked the voltage off of the cables and the grounds next to the battery. Should we be checking resistance instead?
Thanks for your help.
