I don't plan to drive my van much at night if possible, but when/if I do, I want the best headlights possible without spending a fortune or wasting money on cheap HID conversion kits that tend to die after a week.
Having 7" round sealed beams, my options are somewhat limited unless I venture into conversion kits which I'd rather not do for this application.
Based on the research I have done, it seems that the Sylvania H6024 XV XtraVision sealed beams may be the best ones you can get in terms of viability.
They do make the H6024 ST SilverStar, but based on their very own examples it seems to be inferior in terms of visibility distance. It generates greater brightness closer but falls short of longer distance visibility. It also seems to create more washout from excessive brightness. (See chart below)
I had a pair of (non-sealed beam) XtraVisions in a 91 Corolla and they helped considerably over the standard bulbs it had when I got it. It was very hard to see at night before I put them in.
