Originally Posted By: bullwinkle
If you steered clear of the early ones ('03 pickups, '04 everything) your luck should have been better. I know Ford had improved head gaskets by '06 (when they did my van) and they must have slightly better EGR coolers now too. Just be advised that the 6.0 is probably the most complicated, hard to work on diesel engine ever put in a light truck-and that most Ford dealerships will know LESS THAN YOU about it if it breaks!!
You are correct. For any major work, the cab of the truck has to come off to access the engine or the engine has to come out. No way around it. And yes, Ford techs (for the most part)are diesel dumb. Try to find somebody that works on International trucks....they (more or less) use the same 6.0 engine.
