i just got an extra car. a 2001 impala ls with the 3800 engine. It seems these engines are fairly easy on oil. just wandered if anyone has settled on a favorite oil and filter.
I'm not saying that you cannot have a intake gasket leak in the 3.8. I was simply stating that it is not one of the "infamous" gm engines w/ that problem.quote:
Originally posted by cobra3757:
Wrong i have a 3.8 olds and i had the intake casket leak.
I have personally poured over everything avalible on this site and elsewhere on the web-a-tron with respects to the GM intake gasket problem and weather or no the 3.8 is affected. After doing this for over a week I thought I had came to the conclusion that it was not and that the 100% failure rate was w/ the 3.1 and 3.4.quote:
Originally posted by m2200b:
3.8 series 2 are near 100% leakers and I would UOA on next change.
The class action lawsuit in Canada points to the 3.1, 3.4, 3.8 and 4.3 liter engines as having the intake manifold issue. I found this with a quick search on that web-a-tron thing. With a thing called Google.quote:
Being that I am an owner of a Series II 3.8 you could imagine that I would be very interested in this subject. Since you know that the 3.8 has the 100% failure rate, please do me the favor of pointing me in the direction of where you found this information.
The 3800 Series II had its own intake/coolant problem. The upper plenum would warp and allow coolant into the lower section. If left long enough, it could allow enough coolant into the intake runners to hydrolock the engine.quote:
The 3.8 doesn't have the intake gasket issue. It's the 3.1 and the 3.4 that have problems.
