I can help...
You can rule out Fe from your cylinders because true to its racing
intent your CBR sports an aluminum composite sleeve is used in place
of a conventional cast iron sleeve... The composite sleeve contributes
to lower engine weight and enhances cooling efficiency which enables
higher compression ratios...
Honda manual specifies SAE 10w30 Pro Honda GN4 or an equivalent 30
grade motorcycle oil... I gather you have up graded from GN4 non
synthetic recommendation to Honda full synthetic HP4S...
First of all Honda's engineers can be trusted... they would advise you stay
within the 30 grade but search for an improved motorcycle oil more to your liking...
More 30 grade support...
Quote Amsoil
60% of total engine wear occurs during cold start up
conditions before oil can circulate through the engine...
Quote Lake Speed Jr certified lubrication specialist at Driven Racing Oil.
“While a thicker viscosity grade is a workable solution, remember that
70 percent of engine wear occurs at start-up, so a higher viscosity
grade actually causes more wear, and we have used oil analysis that
shows this,” says Speed.
Quote 540Rat
"Thinner oil flows quicker at cold start-up to begin lubricating
critical engine components much more quickly than thicker oil can.
Most engine wear takes place during cold start-up before oil flow can
reach all the components. So, quicker flowing thinner oil will help
reduce start-up engine wear, which is actually reducing wear overall."
Quote EAA ( Experimental Aircraft Association)
"When we first crank the engine, there's no oil pressure and the
crankshaft cranking speed is pathetically slow. The conditions for
hydrodynamic lubrication simply do not exist. Consequently, there is
metal-to-metal contact between the journal and the bearing, and wear
is inevitable."
Quote SAE
Wear of engine components is affected by lubricant quality and flow
and by the metallurgy of the rubbing parts. Recent studies have shown
that after starting an engine at sub-zero temperatures, more than 6
min elapsed before oil reached all of the rocker arm assemblies of a
V-8 engine. Since this could have an adverse effect on rocker arm and
ball wear, the effects of intermittent and zero oil flow on rocker arm
and ball wear were investigated.
Info you... Used Oil sample shows that a Honda 30 grade in a CBR1000RR
will meet and exceed your mileage expectations... your engine just
happens to show different numbers at this time..
