they hold water around them and snap very often when you’re removing them.
The head on the one I broke looked brand new still, so I’ve yet to touch another injector rail. When I do oil coolers I don’t remove the injectors or fuel rail anymore. I only did it before because the rear 3 injector connectors are not visible on a promaster so unlocking them and disconnecting was a little hassle. Now I don’t remove the connectors or the rail. Guess that’s a benefit of working on them on an almost daily basis. But I’ve never needed to replace injectors for any reason yet.I did see all those silver "timber bolt" looking fasteners and even the upper intake when I had it off for the gasket gave me sweaty palms.
If the screws still look new am I safe or will the heads look new with rusted threads? Last time I was in there all looked very clean but who knows.
But it’s my understanding that promasters are the only 3.6 that don’t have an engine cover, so water is able to get to the upper intake and pool up where it isn’t on any other 3.6 model?
My only problem I’ve experienced with the upper screws is rusted heads. I’ve always been able to hammer a socket onto them and get them out, I’ve seen guys online say they have to dremel the heads off then extract the screw once the intake is off.Coincidentally this one is a Promaster and does have a cover over the intake. Not the newer 2 piece where there's a square hole in the center, this is a solid cover.
The upper intake looks new on this motor, we had the upper off before and all the screws for the upper intake were silver all the way down.
The injector was reading 230 ohms and threw a code, now it's down to 30-40 with some cleaning, still won't seat correctly if I'm diagnosing it correctly...code is popping up again so we are going to replace it.
The fuel rail screws are the ones that look fine till you touch them
I don’t think new ones will fix it if they break. If I remember right, you can drill out the broken piece, but since it’s a large self tapper, a new screw isn’t going to grab and do anything for you. There was room (with the intake on a bench) to use a long m8 or small bolt, with a nut underneath. You’ll just have to know that any fuel rail removal will require working on it on the bench from now on.Thanks, I'll probably pick a few spares up just in case.
Go to Rock Auto and buy the Bosch 62410 (0280158233) for $44. This is the exact same injector as the OE Mopar that cost $100.Are OE injectors the ones to get or aftermarket?
