Originally Posted By: buster
Originally Posted By: Clevy
Another Mobil 1 UOA with high Iron counts. Nothing to see here folks, move along...
Which anyone who actually knows what they're talking about will tell you is absolutely meaningless.
How many times must it need to be posted. A used oil analysis is NOT in any way shape or form an accurate indicator of wear.
So there could be high ppm iron in the oil and it really doesn't mean anything.
Uh, it is wear. A basic UOA will be limited, and wear tolerances will vary, but it's wear.
http://www.anac-diagnosis.com/lub/lubana...&LG=EN&
But this isn't formula 1 buster
Nor do I believe the process is all that similar. You aren't getting Formula 1 grade oil analysis results for $20.00. And I'm also quite sure they use UOA's coupled with tear-downs like they do in many other racing venues. There is a clearly defined process with the Formula 1 system (and that's what it is, a system that includes oil analysis as part of it) that is the way it is due to rules and regulations as well as what has shown to work. As somebody else said, it allows them to modify fuel trims and other operating parameters as well and the lube is a constant; they always know what is in the engine.
