Originally Posted By: doitmyself
The PVC system was much to blame for the sludge problems up until about 2003/04, when they re-designed it.
The water pump is also an issue. As it begins to go bad and leak (bearings), the coolant can be directed into the crankcase.
When my daughter's water pump went bad (impeller broke apart), a UOA indicated no coolant in the oil. BUT..........the new, improved water pump design has a different timing chain pulley, so a new water pump also requires an entire new timing chain kit. Fortunately, I am friends with a MOPAR mechanic that does work on the side for about $40/hour. He has been my hero many times and I take care of him well.
Several mechanics I talked to about this engine said they prefer not to work on them due to all the headaches with customer come backs.
My 2000 Concorde 2.7 has 80K on it and runs perfectly. Probably around 100K I plan to replace the water pump. Is it necessary to use OEM parts or are any of the aftermarket part good enough? What did you use and what did the parts cost? Thanks
