Vehicle: 1999 Toyota Tercel
Mileage: 280,000 km (175,000 miles)
Oil: Amsoil Signature Series 5W-30
Miles on oil: 10,000km (6,200 miles)
Filter: Wix (black case)
Miles on Filter: 10,000km (6,200 miles)
No top-up oil.
I recently installed a Frantz oil filter (used a bunch of RTV when I dropped the oil pan and silicone tape during the installation process of the Frantz filter which I think explains the high Si). The toilet paper roll was not changed during the 10,000km interval. I discovered and fixed a vacuum leak from a rotten hose midway through the interval. I also got a VOA for the oil for oxidation numbers. Particle Count was using a laser optical (ISO4406) methodology. Lab was Metro Tech Systems in Canada. I've never put oil in for more than 10,000km but I think I'll keep this one in for another 10,000 with a new tp roll and filter (and about a quart top-up), maybe get another UOA then. I'm happy with what I see.
Code:
Used Virgin
Metals:
Tin 0 0
Lead 1 0
Copper 2 0.2
Aluminum 1 1
Silicon 75 2
Iron 3 1
Chromium 0 0
Silver 0 0
Zinc 769 794
Magnesium 14 15
Nickel 0 0
Barium 0 0
Sodium 1 4
Calcium 2000+ 3428
Vanadium 0 0
Phosphorus 675 689
Molybdenum 132 140
Boron 104 241
Manganese 0 0
Physical Properties:
Vis (D445) @ 100C 10.49 10.88
Water (D4007) (% v/v) 0 0
Glycol No
Fuel Dilution No
Other Properties:
Base No. (D2896) 8.43 12.44
Oxidation 6.89
Nitro Compounds 3.06
Organic Nitrates 14.54
Particle Count (ISO 4406) 19/17/14 17/14/10
No top-up oil.
Code:
Used Virgin
Metals:
Tin 0 0
Lead 1 0
Copper 2 0.2
Aluminum 1 1
Silicon 75 2
Iron 3 1
Chromium 0 0
Silver 0 0
Zinc 769 794
Magnesium 14 15
Nickel 0 0
Barium 0 0
Sodium 1 4
Calcium 2000+ 3428
Vanadium 0 0
Phosphorus 675 689
Molybdenum 132 140
Boron 104 241
Manganese 0 0
Glycol No
Fuel Dilution No
Other Properties:
Oxidation 6.89
