1995 Ford Escort wagon
Connecticut
My younger cousin has a beater car to drive back and forth to college. Its a '95 Escort wagon with the auto trans and 145,000 miles on it. Hes looking to get the most mpg out of it. What oil should he run in it? I was thinking PYB 5w20. Any suggestions on a good oil/filter and change interval?
Well IMO. Since its a beater. Your words not mine. I would run regular Valvoline conventional if it was mine. Any Dino oil would be fine though. Change it every 3-5000 miles and keep up on air filters. Those cars get great mileage
. Just keep it running tip top and enjoy the little gas sipper.
Originally Posted By: chevyboy14
O and I would just run a motorcraft filter they are good filters
Thanks I was thinking a Motorcraft filter since they are pretty cheap at walmart. Any ideas on the viscosity this car needs? He has run 10w30 in it since he got it.
We had a 98 Escort Wagon. I always ran valvoling white bottle conventional and motorcraft filters. Car ran great and stayed clean under the valve covers. Use any conventional you want in a 5w30. My first 2 OCI's with ours I ran 1 quart of Marvel Mystery oil and 3 quarts of Valvoling conventional. No problem at all!
5w30-- cheapest thing you can find...its a beater car.
probably QS green bottle at walmart.
I would run some 10W30 Rotella and go for ultra long change intervals if the car is doing mostly highway miles. Like once a year regardless of miles.
In terms of best mileage, its probably doesn't really matter as long as there is oil in it... If he keeps to the speed limit he'll get decent mileage, 70+ and it will be bad.
One of my friends had pretty much the same car with the same miles and it died of rust, not anything mechanical, and we had an old 91 Escort GT with the same auto and that trans should be bombproof with the slug 89hp 1.9L.
Our daughter had a 94 Escort Wagon while in college and afterwards. She took great care of it and sold it with over
200K on it with no problems, just regular and routine maintenance. Oil used was Mobil 1 5w30 with Fram TG ( before XG's came out ) oil filters. The manual spec'd 5W30 oil.
If the timing belt hasn't been replaced, better do it soon.
It's a non-interference engine FYI.
I used Valvoline Synpower 5w-30 and a Motorcraft FL400s filter back when I was commuting to tech school everyday and ran 7,000 -7,500mile OCI's. I bought it with 60,000 miles on it and it had 167,000 on it when my ex totaled it. All I ever had to do to it was replace the alternator once and the timing belt. I've had bigger, more expensive vehicles since then buy I still miss that thing, I beat the heck out of it and it kept coming back for more. They did have a problem with the rear coil springs rusting through where they sit in the bucket, mine had this problem and another guy I work with had that problem on his too, they were still drivable though.
You're sooooooo right about those rear springs rusting and breaking I forgot about that. The rear sway bar attachments
rusted and broke also. No big deal to replace them though.
Another problem the 1.8 engines had in the Escorts were porous
head castings that did not show until after about 50K miles.
If you were lucky, all you needed was a new head....if not....
a rebuilt engine. I had to pop for one of those in another Escort.
+1. Also 10K OCI will work if the engine is fairly clean through the oil fill hole.
Most of the Escorts around here that have failed inspection and been crushed are due to rust around front suspension members.When that happens,it cant be fixed.
If it's a 1.9, and you ever have to pull the head for ANY reason-be sure to have the valve seats staked in (with a punch), especially the intake seats-#1 reason those end up in the junkyard!
I had a '96 Escort. Fed it PYB 5w30. This car was a 100% short tripper. I got 25mpg on pretty much every fill up.
