Just changed the oil in my daughters first car and while checking the spark plugs noticed the boots soaked in oil. Anyone ever change the valve cover gasket on one of these?
There`s 4 bolts on top of the cover and a hose,looks pretty straight forward but if it isn`t I`d appreciate any help. I couldn`t tell if it was separate from the timing belt cover or if I would have to mess with that or anything else.
Also the car has 166 thousand miles on it. If I can`t find out if the timing belt was replaced recently should it be done? I don`t know if it`s the type that will lunch the engine if it fails(interference?).
Thanks in advance,
Jerry
Thanks in advance,
Jerry
