Originally Posted By: Hokiefyd
The ports certainly got smaller in 1985. I had a 1984 engine and a 1987 engine. I actually preferred the 1987 engine for smoothness...it was a very smooth, very smooth, engine. It also had more off-idle torque than the 1984 engine had. The 1984 engine would spin out a little freer, while the 1987 engine was pretty much out of breath by about 4,000 rpm.
I never even had to choke the 1987 engine in warmer weather. It acted very much like a fuel-injected engine. Both had the same somewhat rudimentary computer-controlled Quadrajet carburetor. I still have Doug Roe's excellent book on tuning Rochester Q-jet carbs.
Alas, the '87 engine had a knock in it. To the best of my recollection, it'd rev up quiet, then clack-clack-clack its way back down to idle. Many suggested a bad wrist pin. Could have been, I'm not sure. That car (an '87 Buick Regal I bought for 500 bucks) had the more desireable 200-4R transmission with 3.08:1 rear gears. My nicer car (an '84 Olds Cutlass) had the 200-C with 2.41:1 gears. Both cars had the F41 suspension, but the rear bar on the Buick had gotten gone at some point before I owned it. I swapped out the 1987 307 for a very much un-computer-controlled 403 from a 1978 Regency 98. Paid $325 for the (running) engine, tore it down, had it bored .030 over with new valves, polished crank, installed a fat Wolverine cam, and had a lot of fun in that car.
Yes, they were pretty smooth, and had great off idle torque. I remember the peak power was 140 hp at only 3200 RPM! The 1985 and newer engines also had more peak toque than the older engines. I had a lot of exhaust leaks on one of my 307's at the exhaust manifolds which kind of made them sound rougher. My '85 had those weird stainless manifolds, but I had more problems with the cast iron ones. My 85 Detla 88 was a Canadian emissions car so it had no feedback carb, just a standard Q-jet. It too started very quickly, I could just touch the key in the summer and it'd fire up. In the winter it'd start without the choke when I used a tank heater even at -30 (the hot air choke shut was disabled by the heat of the tank heater).
I had an Olds Custom Cruiser wagon with a 307 that I had planned to swap a 403 into until the car and engine were distroyed in a garage fire. It was a 1978 Olds 403 out of a Trans Am, with a mild cam and intake. That 307 had a hard time moving that big heavy wagon, especially with trailer in tow. It had the feedback carb, which I rebuilt once during my ownership. I much prefered the mechanical carbs.
