Originally Posted By: IndyIan
Can you get a 185/75R14 tire? I only see the kumho solus available in this size on tirerack.com
Capri racer knows better than me, but I think the wider the tire, the more potential for tire noise, especially on old pavement, also in general a narrower contact patch should have less rolling resistance, but maybe not a significant amount.
Anyways, I kind of like narrow tires for the street, they are better for hydroplaning, and give you a bit of a slip angle for playing on the on ramps while giving you lots of warning when the limit is near.
No, just the 70 series. Yeah, I don't really want a wider tire just a bit taller. I'm hoping at least the MPG will stay the same along with a slightly improved ride. I run the current ones at 30 psi as per recommended by Honda. Maybe I will be able to run 34-35 psi with the bigger tires. Huge difference in ride quality when bumping up current tires from the 30 psi and no noticeable improvemnet in MPG.
That's a great price for those, onebigunion..
