quote:
Originally posted by Bror Jace:
Soupy, there's a lot of discussion about the suitability of 15W-40 for lawn & garden equipment in this subsection. Try using this forums search feature and searching just this subforum using the keyword '15W-40' and you'll get a load of discussion.
Wix/NAPA filters are top notch and I can't believe dealers will sell OEM filters for less than you can get these. I see even tiny OEM filters which look like they are made by Champion Labs, sell for $10-12.
Purolator are fine and should be even a tad cheaper than Wix/NAPA Gold.
Avoid Fram.
I'd use the latest version of Chevron Delo400 15W-40 which has the yellow flag on it saying something about 'new anti-wear formula' as I believe this version has the 200ppm of moly.
I might switch to Rotella 5W-40 for the coldest months if these machines are not stored in a heated area. Cheap ($3.50 per quart) and widely available. Even if this stuff shears a bit, it'll still be close to a 30 weight when hot.
How long do you go (hours) between oil changes?
--- Bror Jace
I have been doing a lot of searches. For a newbie like me it gets a little confusing, but I am learning.
I go 50hrs (oil and filter) even though the manufactures say 100hr and filter change at 200hrs. We operate in extreme conditions so I ignore the Manuel.
I have always used Mobile 1 10W-30 but my Kawasaki (440hrs)drinks it to fast. I'm getting rid of that mower soon, so I will have all Kohler's soon. I think I am wasting money on the Mobile 1 and will switch to Delvac1300S or Delo400 15W-40 and use the synthetic 5W-40 in the colder months. Does Delo400 have more Molly then Delvac1300? I have a 92 Silverado 2500 6.2 diesel (190,000 miles) that this oil will be used in too.
My main goal is to keep these motors running strong for 3 years (around 1000hrs) and sell them off for new. I have no doubt that 1000hrs is easily achievable with the cheapest oils, but I want the new owners to enjoy a reliable mower when I am done with them.
I have always used seafoam a few times a year in the gas and also run it straight through the carbs before storage. I have read a lot of good things about FP. I think I will give that a try this year.
I think once a year I will throw a little A-RX (another product I just learned about) in the mowers too. Probably about 3-4 ounces for 2 quarts and run 25 hours then rinse for another 15.
Do you guys think I should bother giving LC a try? I need to do more searches on it, but I think I am already over doing it. I should achieve my goals easily with the things mentioned above.
I know, I know, a lot of questions. Sorry, I am just throwing thoughts out.
I can't believe I came here for a quick lesson on oil and have been hooked for 3 days searching and reading. This is a awesome site!
