Originally Posted By: Touring5
In much of the country, Summer brings both heat and high humidity. It is essential to properly size the condensing unit, otherwise you'll experience a cool, muggy house. From my time in the HVAC design and manufacturing industry, I was told you want the unit to run around 75% (or higher) during the hottest conditions.
Actually, you want the unit running about 75% of the time during normal summer days. During the hottest days, the right sized unit will run almost 100% during the day and about 75% during night.
Sizing also depends on your set point (temperature that you and your family feel most comfortable with) and it can vary widely from one household to another. The higher the set temp. the less AC capacity needed. Most sizing charts assume set temp. to be around 75F at least for Canada, so that is something to keep in mind when sizing the unit.
It gets even more complicated with two stage or variable speed, high SEER units and as usual many contractors will upsale the size, and they end up working not to the expectations and more importantly, not providing the promised savings in electricity useage.
