Originally Posted By: OneEyeJack
Another thought. Do you have the right size unit?
When I replaced our old unit that came with the house, I did a lot of calculating, measuring, taking temperatures at different times during the day and checked with neighbors that had similar size houses with the same exposure to the sun. They had 4 and 5 ton units. They were happy with the idea that they came on, quickly knocked the temperature down and shut off. They were sold on the idea of the quick cooling.
I did opt for the highest efficiency unit available but a smaller one at 2.5 tons and worked extra hard at improving the insulation everywhere including a lot of stuff to keep the attic clear and cool and replaced some windows and planted a dozen trees. My unit works just a bit longer to knock the temperature down but if feels like it does a better job of also knocking down the humidity. My unit runs 10-20% longer than either neighbor but draws much less current overall.
The neighbors told me the company that installed their units really pushed for the bigger higher performance units and they both say they now wonder if they ended up with too much capacity.
In much of the country, Summer brings both heat and high humidity. It is essential to properly size the condensing unit, otherwise you'll experience a cool, muggy house. From my time in the HVAC design and manufacturing industry, I was told you want the unit to run around 75% (or higher) during the hottest conditions.
