Originally Posted By: RiceCake
I seriously am starting to understand why some menufacturers want their own specifications (like Dexos) as opposed to relying on API service grades.
The differences in oils are rather enormous to say the least which makes for really confusing problems.
It only gets worse when you mix and max other specifications. A 0w-30 SN/GF-5 is certainly not the same as 0w-30 GC with its performance ACEA and manufacturers' specifications. The viscosity grades are fine if one reads the fine print, i.e. the other specs. SN/GF-5? SN only? Dual rated? ACEA A1/B1 or A3/B3? If someone know what their engine specifies, there isn't a lot of risk of accidentally choosing Petro-Canada 0w-30 instead of GC 0w-30 in a European application. Yes, it could be easier, but there will always be differences and mutually exclusive specifications.
