- Dyson Analysis
Customer Name : Dyson Analysis Test Oil Brand/Weight : Redline 10w-30
Type Equipment : 01'Toyota Avalon 3.0L V6 Miles/Hours on oil : 7000
Total Miles/Hours : 42065
Results ppm/% Comments (blank=normal)
Wear
Copper 10
Iron 12
Chromium 0
Lead 2
Aluminum 4
Silicon 7
Tin 5
Additives
Molybdenum 693
Sodium 13
Magnesium 18
Zinc 1678
Potassium 5
Phosphorus 1574
Calcium 4731
Physical Properties
Water negative
Fuel negative
Antifreeze negative
Soot 153 Host oil is being read as a solid. NA
Oxidation 33 17%
Nitration 22%
Sulfur 24
TBN 9
Vis@100 C 10.1 30w
Final Comments : This is a consolidated(mutilple lab) test with a 50/50 mix of in town and highway driving.
MPG affected somewhat by vis stability of Redline. No precursers of sludge formation detected.
oil filter Motorcraft FL-793, original Toyo air filter. Nil,0 oil consumed. Capacity 5 qts.
Terry
[ December 05, 2002, 02:42 PM: Message edited by: Terry ]
