Here is the latest oil analysis of my GTI. This latest scan is with Mobil 1 TDT, the previous one with Amsoil Series 3000 5w30, and the original with Mobil 1 0w40. I am running Shell Rotella 5w40 now.
Jim 5 said:Does the TDT carry the right approvals for this engine? A good friend of mine bought an '09 Audi A4 with the 2.0T and was asking me what oil he should use. I was thinking GC or M1 0w-40, but TDT might also be a good choice. /quote]
502 is a low standard. Many oils that are not tested for that spec show much better real world performance than the 502 oils in this engine. Many 502 oils seem to be lacking in several areas for this engine IMO (f.e. shear stability, flashpoint retention, ZDDP levels, volatility). For example exactly zero 40 weight 502 oils have stayed in grade on the over 45 total UAS we have for this engine. Some shear all the way down to a 20 weight as I recall. Many show elevated iron levels.
Personally I would use an ester based oil with a very strong additive package. Some ester and/or PAO and/or group III oils to consider are: Amsoil DEO, Rotella synthetic 5W40, TDT 5W40, Redline 5W40, Renlube Biosyn 5W40, Motul 300V, Motul X-lite 0W30. Some of those oils we do not yet have data in the 2.0 FSI database but I think would work well based on their specs. (feel free to ignore).
If I had to use a 502 oil, I would use X-lite 0W30 or other higher end Motul oils that are on the list, or GC. I would not run the more traditional 502 oils in this engine. They don't cut it IMO. These engines need a stout oil. The 09' engine you mentioned is a TSI and wouldn't suffer from the cam follower issue though.
