I have an older Ford 3000 diesel farm tractor built in 1973, and with all this ULSD/CJ-4 controversy, I need some advice from you Pro's
out there.
Since there's a lower amount of sulphur in diesel fuel now-a-days, I've been told to use(and have been using) an OTC additive such as Diesel Kleen to make up for the lack of sulphur in the modern diesel fuel, as I've heard ULSD is tough on older diesel engines.
And now, from what I understand, the newest CJ-4 oils have less zinc. But some say that that's ok since ULSD and the new additive package in CJ-4 seem to work well together in newer diesel engines.
What I'm wondering is:
Would it also work well in older diesel engines that were older technology and somewhat dependant on the sulphur and zinc in the fuel and oil?
Should I still use an OTC additive to the fuel and/or perhaps the oil, to make up for the loss of the sulphur & zinc? Or would that conflict with the compatability of ULSD and CJ-4?
Also, since oil technology has come such a long ways since the tractor was built, should I still use the straight HD-30WT dino? Or would a HD multi-vis(15W30, 10w30, 10w40, dino or syn) be better?
I appreciate your advice.
Ronnie
Ronnie
