The information you want is in SAE Paper #981444, entitled: "Advanced Synthetic Passenger Vehicle Engine Oils for Extended Oil Drain Performance"
Presented by Mobil at the 1998 Fuels and Lubricants Meeting of the SAE
the infamous "aunt millie test", probably the most destructive oil test ever invented, don't try this at home kids, we are trained professionals....
1. The aunt minnie test is the test of "the severity on the engine oil during this type of testing is attributed to conditions where the engine rarely reaches optimum operating temperatures."
2. The driving test consists of two short cycles, a 3 mile and 1.5 mile test.
3. "Under this severe driving condition, synthetic oil can provide excellent protection against engine wear and deposit formation."
4. The bulk oil temp ranged from 90 C in the summer to 30 C in the winter.
5. Fuel dilution was as high as 11%.
6. Cleanliness was excellent, the deck sludge rating was 9.7 out of 10.
7. "The iron content showed a low rate of increase, only 100 ppm after 40 months, although there has been a steady increase to over 600 ppm over the last 22 months. The source of iron has not been determined, as visual inspection of the engine did not indicate any abnormal wear or corrosion. In addition, elevated iron levels have not appeared in other test vehicles operating under 'aunt minnie' conditions."
The oil was a 5W30 running in a 3.1 L V6 with no oil drains.
The oil volume sampled was 5.5L and make-up was 4.4L. TBN retention was 33.
Test duration was for 60 months.
if synthetic will last 5 YEARS under these conditions, i think any TIME interval is strictly for your memory, not for the oil. note that some manufacturers say that oil SHELF life is 5 years (what, you wanted consistency???). actually, the bottles may start coming apart after then.
