Home
Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler
Posted By: dhellman12
Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler - 06/01/19 01:59 PM
First full run with Amsoil Signature series oil. This oil was changed when the Jeep oil light came on at 7,500 miles.
Make/Model: Jeep Pentastar 3.6L v6
Vehicle: 2012 Jeep Wrangler Unlimited Rubicon
Code
OIL             Ams ASL 5w30	Toy 5w30
MILES IN USE    7,543		4,283
MILES ON UNIT   72,826		65,283
SAMPLE TAKEN    5/11/19		9/12/18
MAKE UP OIL	0		0
ALUMINUM	3		3
CHROMIUM	1		1
IRON		10		8
COPPER		9		10
LEAD		0		0
TIN		0		1
MOLYBDENUM	178		51
NICKEL		0		0
MANGANESE	0		0
SILVER		0		0
TITANIUM	0		1
POTASSIUM	3		1
BORON		49		13
SILICON		16		16
SODIUM		11		9
CALCIUM		1252		1900
MAGNESIUM	761		221
PHOSPHORUS	650		683
ZINC		725		793
BARIUM		0		0
SUS @ 210F	60.4		53.5
Visc @ 100C	10.34		8.33
Flashpoint	395		415
Fuel %		<0.5		<0.5
Antifreeze %	0.0		0.0
Water %		0.0		0.0
Insolubles %	0.3		0.2
TBN		3.5
Blackstone comments:
These are some nice results! Even though you ran this oil a good deal longer than the last, there's hardly any more wear to show for it. The 3.6L Pentastar powering your Jeep looks like it had no problem with the additional miles, and the oil itself held up well, too. Its viscosity is still in grade, no contamination was found, and the TBN is a strong 3.5 (1.0 is too low). The air and oil filters did a good job, too, based on the normal levels of silicon and insolubles. This all adds up to an ideal report, so feel free to run the next oil even longer. Check back after ~9,500 miles.
Posted By: oil_film_movies
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler - 06/01/19 02:18 PM
Blackstone comments are good. (They aren't always!)
Healthy engine with a great oil. No bad numbers. Could have gone another 3,000 miles with that high TBN at the end.
Originally Posted by dhellman12
Amsoil ...This oil was changed when the Jeep oil light came on at 7,500 miles.
Using higher-spec oils than what the engine computer software algorithm (OLM) assumes you're using, especially in a low-soot port fuel injected engine, means you could possibly go about 1.5x the dashboard light time and miles. I'd use a Fram Ultra XG10955 to match the performance of Amsoil SS, M1 EP, M1 AP, Castrol Edge EP, Ravenol DXG, or Rotella T6 Multi-Vehicle in there.
My 1.5T DI gasoline 'soot-maker' (GM 2018) defeats just about any oil at 7,500 miles according to GM.
Posted By: Triple_Se7en
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler - 06/01/19 03:49 PM
Nice results from a real nice oil. I would keep running it for 7.5K. What oil filter was on that run?
Posted By: JLTD
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler - 06/01/19 04:41 PM
10k would be a walk in the park for this oil. What filter are you using?
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler - 06/09/19 03:36 AM
On that run I was using a Wix filter. On this run I switched over to the Amsoil EA as I'd assumed the report would show it would be safe to extend the OCI out even further.
Posted By: JLTD
Re: Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler - 06/12/19 11:29 AM
thumbsup Thanks - areyou planning 9500 ... or further?
© 2020 Bob Is The Oil Guy
