Home
Difference Between Drivers Side and Passenger Side Caliper
Posted By: Fitz98
Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 02:46 AM
I went to AZ to buy a new driver side caliper today.
No reason to think there was any issue and everything installed fine, until I went to set the brake pads and noticed the driver side caliper installed differently than the passenger side. One side I had to install the top first and push in the bottom and the other side I had to install in the top first and then push in the bottom.
That got me thinking to compare.
The bleeder screw is on the top on the passenger side, but on the bottom of the drivers side.
My original driver side has the bleeder on the top as well.
The part number on the box matches the correct image that matches my original caliper, but is different than the one that was in the box.
Seems like someone did me the favor of returning a passenger side caliper in a drivers side box, which would explain all the grease on the box itself when I picked it up.
Shame on me for not checking before installing.
I imagine the bleeder should be on the top. Does that sound right?
[Linked Image]
[Linked Image]
AutoZone Driver Side Caliper
Posted By: bdcardinal
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 02:49 AM
The bleeder has to be on top in order for the brakes to be bled. That looks like a mis-box.
Posted By: Fitz98
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 02:54 AM
I figured as much. Lesson learned I guess...always check before installing. The differences are very subtle, but important.
Posted By: DuckRyder
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 03:03 AM
Doesn’t it say “RH” right on it?
Posted By: Nick1994
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 03:21 AM
Very important that the bleeder is on the top.
My brother and I reinstalled the front axle in his Jeep after a rebuild and could not for the life of us get the brakes to gain pressure whatsoever until we realized the calipers were swapped.
Posted By: hallstevenson
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 03:39 AM
Think of the bleeder screw as an air vent as well. You bleed fluid and air out of them on occasion.
Posted By: bobbobtar
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 04:14 AM
I found out the hard way installed one with the bleeder on the bottom worked almost an hour trying to bleed the system neighbor stops by and looks at it and say's the bleeder should be on top. Thanks, parts store.
Posted By: MarkM66
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 02:12 PM
In a pinch, you could always bleed the caliper off the bracket with the bleeder pointed up, then install into the bracket.
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 05:20 PM
That would work. Just have to make sure something is between the pads to keep the pistons from compressing.
Posted By: Miller88
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 05:46 PM
The problem I always have is the parts store bleeders are always so tight. More than once I have snapped the bleeder off trying to bleed the brakes. Now I always make sure I have a wrench with me at the store and loosen up the bleeder before I start.
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/21/20 09:41 PM
I have bleeder screw wrenches which are basically really long 6 point wrenches in the common bleeder sizes. You can also use a 6 point socket and a long 1/4" ratchet.
Posted By: another Todd
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/23/20 01:03 AM
The calipers on my car dolly has bleeders on the top and bottom so they are interchangeable left and right. I don't know why more manufacturers don't do that if they are otherwise interchangeable, they would cut in half the part numbers for that application.
Posted By: slacktide_bitog
Re: Difference Between Drivers Side and Passenger Side Caliper - 02/23/20 02:12 AM
approved
© 2020 Bob Is The Oil Guy
