Home
Replaced transfer case fluid today
Posted By: buck91
Replaced transfer case fluid today - 06/03/18 03:53 AM
As the title says, replaced the transfer case fluid on my 2011 F159 today. Factory spec is 100-150k miles, this is the first change at just short of 100k. Fluid didn’t seem grossly out of viscosity but was grossly contaminated with grey goop/particals and possibly some moisture. Ford specs a “transfer case fluid” now that mercon is no longer officially produced so I don’t know if they are using anything fancier than the old mercon but I am certainly not impressed. Put Amsoil multi vehicle atf in and plan to change every 30-50k from here out.
Posted By: 4WD
Re: Replaced transfer case fluid today - 06/03/18 03:57 AM
I’m going to stick with early … with Ford PTU’s out of my life … the GM’s seem so easy …
Posted By: demarpaint
Re: Replaced transfer case fluid today - 06/03/18 09:05 AM
I'm sticking with early too in my Jeep. I did the Liberty at about 30K, my Rubicon will be getting it done within the month at just over 10K miles. I'll probably go to 50K intervals after that.
Posted By: littleant
Re: Replaced transfer case fluid today - 06/03/18 12:28 PM
IMHO Ford Spec are way to long at 100-150,000 miles on Trans and Transfer case. I do question the rational for there maintenance schedule. I use the severe service. There is a specific transfer case fluid. Motorcraft xl-12 Transfer case fluid
Posted By: berniedd
Re: Replaced transfer case fluid today - 06/03/18 01:06 PM
It is a good idea to replace earlier than what the manual says. Their recommendation is to get past the warranty with minimum of cost, not in the owner's best interest for long equipment life. I changed my Ford SUV rear diff oil at about 22,000 miles and it came out greyish in color (suggesting water or water vapor contamination). It had always been driven only on the street, never off road or in flood. Manual also says change the ATF at 150,000 miles. I am definitely changing earlier than that.
Posted By: buck91
Re: Replaced transfer case fluid today - 06/03/18 01:39 PM
I agree; did ATF and coolant at 80k with planned bi-yearly drain and fills after that. After doing a lot of reading I decided to to the front dif and t-case at 100k (50k early). After this t-case drain I'm sure the front dif fluid will look terrible when I finally crack it open. Rear dif was done a couple years back when I installed my posi.
Posted By: Kestas
Re: Replaced transfer case fluid today - 06/03/18 01:49 PM
I urge people not to wait 100K to change out the fluid in their transfer case units. Manufacturers are pushing this fill-for-life concept in their new designs and the bearings are suffering short lives from debris denting. The problem is so bad that bearing manufacturers are asked to come up with debris dent resistant raceways, which is expensive, difficult, and a backwards way to manage the problem. The fluid should really be changed out early after break-in. 20K is a good suggestion. I only see the bearing problems. It's a good bet the gear teeth have a similar problem.
Ditto for transmissions and differentials.
Posted By: IndyFan
Re: Replaced transfer case fluid today - 06/03/18 01:52 PM
I usually go ever 36k or thereabouts. 123k on my JK now. The last change was at 96k, so it is due soon. I think the longest I ran that unit was 50k. The fluid came out looking brand new. Still, I like peace of mind. It is as cheap as a couple of bottles of ATF.
Posted By: 4WD
Re: Replaced transfer case fluid today - 06/03/18 02:08 PM
On our 2015 Explorer Sport… the shocker to me was the OM stated 150k … but then you flip around several pages back … and severe service is 30k ! Why not have that on the same page.
And BTW, when you have only 18 ounces of fluid to manage ecoboost torque … and being cooked by dual exhaust 3” below PTU … you’d reach “severe” PDQ …
Posted By: zeng
Re: Replaced transfer case fluid today - 06/03/18 02:17 PM
These problems are caused by too low an operating viscosity (i.e too low a [email protected]*C) or too long an OCI ? .....
wait aren't they of superior base oils AND add pack ?
Application blunders simply could not be resolved by non-application remedies, I suppose.
Posted By: Rand
Re: Replaced transfer case fluid today - 06/03/18 02:27 PM
I agree on the short interval.. its esp. important on the first change.
I changed the gear oil on the 2013 outback at 15000miles the front
which shares with the 6speed transmission was very silty.
The rear looked very bad as well..
Subsequently
I went to 30k-40k mile intervals and both look nowhere remotely as bad as the first short 15000 interval.
Posted By: Kestas
Re: Replaced transfer case fluid today - 06/03/18 03:28 PM
The problem is not the oil, per se. It is the break-in debris that floats around with the oil. Manufacturers have now asked suppliers to guarantee a limit on how much debris is present on the parts used for assembly. They are making design and manufacture of components very difficult in the name of chasing the almighty fill-for-life concept.
Again I repeat, change the fluid early after break-in. You'll see all the crud come out. The first change looks like metallic paint. The next change, whenever it is done, will come out considerably cleaner.
The lubes specified are fine.
Re: Replaced transfer case fluid today - 06/03/18 04:35 PM
Spot on! It's the break in [censored] you want out early. The fluid unfortunately has to go too.
Re: Replaced transfer case fluid today - 06/03/18 06:43 PM
How many ways can I agree with the above. 1000% should do it.
Posted By: 69Torino
Re: Replaced transfer case fluid today - 06/04/18 02:10 AM
Agree with everything stated here. I do all my driveline components (drain and fill) more often than recommended. Diff’s, transfer cases, transmissions. At least every 30k, and absolutely as soon as I buy a used car. Every fluid. It’s expensive once, but I now know what the gears and bearings are swimming around in. New cars I can barely keep from dumping and filling the driveline components before the 10k mark, and every single one I’ve done has had stripper dust in it.
Posted By: Falcon_LS
Re: Replaced transfer case fluid today - 06/04/18 10:03 AM
My Explorer specs Mercon V, I stick with 12,500 miles since its real easy to do. Too short, maybe. But it still comes out a bit dirty even at that mileage and I'd rather have fresh fluid in there than that stuff.
Posted By: racin4ds
Re: Replaced transfer case fluid today - 06/04/18 01:42 PM
Since on the subject of T-case fluids, I just changed the fluid in my 05 F350 about 5 months ago but it got me to thinking... why do we use the super thin, not-so-heavy duty ATF in these things?? With the chains, gears and bearings in there, shouldn't we be using some form of SYN gear oil??
Posted By: Kestas
Re: Replaced transfer case fluid today - 06/06/18 02:32 AM
It's a balancing act... thick enough to protect, but thin enough to prevent power loss.
Posted By: Pitbull
Re: Replaced transfer case fluid today - 06/26/18 09:22 PM
LX570/Landcruiser uses a special 75 way oil in the transfer case real expensive stuff 80 bucks later if you go off road dusty dirty roads consistently then they consider that severe service and recommend a 30,000 mile transfer case chain if you tow trailers and boats they recommend a 30,000 mile differential fluid change if you don’t go off road they don’t have a change interval
Posted By: 93cruiser
Re: Replaced transfer case fluid today - 06/30/18 03:07 PM
I used to do my diffs, manual transmission, and transfer case. Then I stopped, even the factory fill was always clean. Maybe toyota has better tolerances/parts, but my oil was always clean, with a fine film of grey silt on the magnetic drain plug.
Same now on auto transmissions, no change. Fluid always looks new, no combustion, done.
I also dont flush my brake lines. Or flush coolants.
Change the oil, lube drivetrain, that is all. Everything else is really not needed anymore in my opinion. Waste of time and money in most instances.
Your mileage may vary, and just what I do. 11 years/165k in my latest truck, owned since new.
Posted By: SOHCman
Re: Replaced transfer case fluid today - 06/30/18 04:26 PM
If you changed the fluid out early in its life, thus removing break in grit, thats exactly why the fluid still looks new later in life. You cant see the viscosity loss and additive depletion, so I'm not sure the fluid coming out "looking new" is a good reason to stop maintaining the fluids on a vehicle.
Posted By: dubber09
Re: Replaced transfer case fluid today - 06/30/18 06:15 PM
Auto industry 'fill for life' means warranty duration, if you understand that - then you understand what to do.
© 2020 Bob Is The Oil Guy
