Originally Posted by tundraotto
Looks solid -especially the [email protected]
With the moly there it just shows that you can have small amount of moly in wet clutch applications without worry. (ie. rotella, delvac etc)
Exactly.
My 2016 Goldwing owner's manual specifically warns against using oil with moly but I've noticed no negative effect in shifting between this and the factory fill (I'm assuming was Honda GN4). The foot shifter has actually become smoother when engaging a gear shift.
First UOA for the bike will be the bike's second oil change in spring/summer, will see what comes back. Some shiny metals in the first change, hopefully it's all gone now!
Thank you for this. I bought the clearance Castrol Power1 4T on clearance at AZ for $4 a quart i think. There is very little info on the Castrol 4T oils.
Just to add, even though this oil is API SL rated, the detergent package ( Ca ~ 1360ppm + Mg 900 ppm = 2260 total) looks like a modern API SN-Plus package tuned for LSPI control.
