Hey guys I recently put four new NGK platinum spark plugs in my car. The next day, I did some more maintenance and cleaned the throttle body with Carb Cleaning Spray but, I think I used too much and got some into the system cause the car smoked and rattled like crazy for about a minute after I turned it on. After it went back to normal, the "Service Engine Soon" light came on. When my friend used his code reader on it, it indicated (Bad Spark Plug No. 4) So, I figured the plug was defective from the factory, since it was new. Well when I pulled it out, it was all fouled/dirty just like the old ones I had replaced the day before. I went to exchange it for a new one and the guy at Napa was ok with it. Now I made the connection that it was probably a good plug and the Carb cleaner burning fouled it up to the point of failure. Also, I'm thinking that the other three are probably all dirty too. They probably aren't as bad as #4 was but I'm thinking I should pull them out anyways and clean them rather than buying new ones since they probably won't believe me that all four could have been faulty. So, what could I clean them with and not damage them? They are platinum $. I was thinking Carb cleaner and a toothbrush, just as long as I let them dry out really well before putting them back in. Or, should I just buy three new plugs? Let me know what you think ok.
Thanks.
Thanks.
