6VD1 engines from Isuzu 1998-2001 are prone to oil consumption problem. It is widely belived that there are some really small drain back holes in the piston housing that lets the oil drain back to crankcase are too small and few, this blocks the flow of oil back to crankcase and hence oil burns out. That is the reason why I am using a lighter weight diesel oil. The first sample was for 6K miles on the oil and second sample was taken at 10K miles on the oil. I had change the oil filter at 6 K miles on the oil and while changing filter I put RA series filter mag on it, that might explain lower Fe in the later sample.
The oil is Castrol Elixion 5W-30 and BG MOA added to oil that is where some of the sodium comes from.
I have a high flow K&N cone filter, some of the higher silicon might be from me tryin to clean my EGR tube which I do every 4 K miles or so.
Both the filters were ISUZU OEM. The first one was without filter Mag.
Comments/suggests on the UOA are appreciated.
Thanks,
-Ankur
