2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
Sinopec 75w-90 Synthetic
by jdw1222 - 11/16/19 12:51 PM
Honda Oil Filter
by miden851 - 11/16/19 12:28 PM
VOA for QSAD 10w-40?
by natas - 11/16/19 12:02 PM
Ford v Ferrari - anyone seen the movie yet?
by Oro_O - 11/16/19 12:01 PM
billad67, aka_Claus, Diverdown, natas, matt3540
69886 Registered Users
96 registered members (2015_PSD, 4WD, 69GTX, 14Accent, 10 invisible), 1,984 guests, and 23 spiders.
Topics297,520
Posts5,117,279
Members69,886
Most Online3,589
Nov 2nd, 2019
The Story With Additives - Rebuttal #803373 01/04/07 06:28 PM
H
heathenbrewing Offline OP
H
I do see where this test could prove some points and where it can also use a bit more re-testing. Due to the fact that this device they used doesn't generate the same amount of heat that an engine block would or a differential, some of the facts they proved were not 100% true b/c they didn't add in a temperature factor. Cooler air has more oxygen in it correct? Correct. So, if these machines are run at room temperatures or basically, any temperature below standard engine operating temperature, they are flawed. As the oil is heated up throughout the block, any air trapped within the oil or the block itself is evaporated/disintegrated into it's molecules. With the constant heat found within the engine block, I would suspect that the air bubbles found in this test would be very minimal in a real engine block or differential test.
But, I do see how this test can have some validity in just presenting numbers, but not as much in a real life test.
Your thoughts?
Re: The Story With Additives - Rebuttal [Re: heathenbrewing] #803374 01/04/07 06:39 PM
doctorr Offline
Your post would probably make more sense if it was in the thread where it all started....
As is, I can only ask "what test?" and "what device?" etc.
doc
Re: The Story With Additives - Rebuttal [Re: doctorr] #803375 01/04/07 06:42 PM
P
Patman Offline
Global Moderator
Global Moderator
P
He's referring to the additives story on the main page of this site.
2018 Corvette, 17k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 152k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,121k, GC 0w40 & Fram Ultra
Re: The Story With Additives - Rebuttal [Re: Patman] #803376 01/04/07 07:38 PM
H
H
Oops..my bad. Heres the article in question:
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Re: The Story With Additives - Rebuttal [Re: heathenbrewing] #803377 01/04/07 07:51 PM
Y
yugrus Offline
Y
The air itself is the mixture of different gases, most of it is Nitrogen, the Oxygen comes second.
I don't see how the air, being gas, would evaporate. It can not disintegrate further down then N2, O2 and the rest. So the bubbles will still be air, heated-up, but air.
Because the gas tends to expand when heated, the bubbles will most likely tend to be bigger and less stable in the oil that is thinner because of the heat.
So the final outcome at operational temperature might indeed be different, the aeration could be less.
But then the tests are valid during the cold start-up, and that's when you get most wear...
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: The Story With Additives - Rebuttal [Re: yugrus] #803378 01/04/07 09:02 PM
H
H
Thanks...was trying to answer a comment by another Scion owner. I stopped taking caffiene, so I am a bit slow in the mornings.
That says it all for me. Thanks!
Re: The Story With Additives - Rebuttal [Re: heathenbrewing] #803379 01/05/07 02:28 AM
R
rpn453 Offline
R
That demonstration doesn't directly simulate any specific real-world application. It simply demonstrates that undesirable things can happen when you modify a lubricant that is already engineered and proven to be suitable for a specific application.
2004 Mazda3 GT Hatch 75k
