My Grand Marquis is having a rattling sound under the hood, which is noticeable inside the car. It is noticeable in Park, and Drive/Reverse at idle, but as I accelerate it diminishes (or at least I can't hear it). The engine has not always done this, I first heard it last year when I was flushing my transmission.
The rattling seems to come from the PCV valve, as when I remove it, the rattling COMPLETELY goes away. I even replaced it with a brand new Motorcraft PCV valve, and the rattle is still there.
There is no oil consumption going on, and no Check Engine Light is showing up. The PCV vacuum line is completely clear of debris, so I do not believe there is something limiting air flow into the intake.
Is this an issue? I would think it is stressing the PCV valve spring inside.
Any idea of what could possibly cause this? Blow-by, IAC valve, MAF sensor?
Thanks in advance.
Thanks in advance.
