I think the analysis looks great. The metal wearing is starting to show a lowering trend. I used a Wix filter during the 6,600 miles. I used a PureOne filter during the first two analysis. I think the Wix filter gave me better results.
Is this the M1, 5w-20 on all three runs? If so it would appear the additive chemistry has changed, or there has been significant additive depletion in this last sample. Specifically, there is no boron left and the Ca level is much lower than before. I certainly wouldn't run this oil longer than 7k miles, based on the last set of data.
The #'s look fine, but I'm puzzled by the change in additive chemistry.
The numbers look really good and should continue to trend down. I agree with TS though. I would not even think about extending this OCI until the 5W20 M1 EP comes out!You might try M1EP 5W30 and see how it does!
It seems to me that when Mobil 1 is sampled there always seems to be unusual wear of some type or the oil has thinned a great deal. I like to change oil often so I use conventional oil most of the year and synthetic oil in the wintertime because synthetic flows easier. I think I will stick with Mobil 1 only for the wintertime.
No, the MDS HEMI is suposed to use a 20 weight only.
Anything higher and the MDS will no function properly.
This is a great example of the changing M1 additive package. M1 used to use over 3k ppm of Ca, 260 ppm of Boron. Ca is very low not so they must being using something else for a detergent.
