Well found one at Fleabay. I preusme it is fairly common ( not custom made ) and can be found for few $s at some oil filter dealer or vehicle parts department if one knew the part # etc .
quote: I preusme it is fairly common ( not custom made ) and can be found for few $s at some oil filter dealer or vehicle parts department if one knew the part # etc .
Grab it ..since with over 2 hours of scouring every known fitting manufacturer there is no "off the shelf" item that is commonly available. This has to be a proprietory item that someone fell into. You can't manufacture a limited use item like that for that little amount in a limited production setting.
I've bought stuff off this vender before. He specializes in lot purchases of oil adapter hardware (Hayden sandwich thermostats, etc.). This guy must be a magnet for this type of stuff.
