Well, I got the pan changed out on Saturday (the 1st). It wasn't too hard of a job, but I did end up having to remove the first section of exhaust pipe. Didn't need to raise the engine though, as it was completely unobstructed w/o the exhaust in the way.
While the pan was off, I checked out what the oil pickup looked like, and it was perfectly clear. No blockages or buildup on the screen at all! Keep in mind that
this is what the engine looks like under the valve cover (that was approx. 7k miles ago).
The pan had a little varnish buildup in it, but I could tell that it was being removed over time. There is a windage tray below the crankshaft that obstructed my view of most of the bottom of the engine. That also had a good layer of varnish, but I could see that the varnish was going away: there were spots clearing up.
Looking at the crankshaft, I could see light varnish on it, but nothing serious, and the cylinder walls were very clean from what I could see of them, as were the piston bottoms and connecting rods.
Overall, I'm quite happy with the way the engine looks inside! I can't wait for 30k miles to go by. Then I'll get to pop the valve cover to adjust the lash and see if there's any improvement. I promise to post some pictures then!
PS. I'm sorry that I didn't take any pictures, but I didn't want to drip oil all over my digital camera.
