If so it gives more evidence that there is a "sweet spot" for oil thats between ~1K and ~5K old. The ZDDP also takes some time to fully activate as well, usually the first 1K miles.
Just a note, I recently removed this catch can from my car. While doing an oil change (after about 2k with the catch can) I found nothing in the can. It had a slight coating on the inside walls, but that was it. No accumulation.quote:
Sorry to bring up an old thread, but I'm curious as to how that catch can is holding up for you. Think it's possible to undo the screws on the inlets/outlets?quote:
Originally posted by 2002 Maxima SE:
Got mine off ebay. Works as advertised. Wallet still healthy.
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=24;t=002724;p=3#000072quote:
I'm currently the high bidder on a Greddy catch can, but I will most likely lose. If so, I'll probably end up getting the same eBay catch can you have, if I can figure out how to stuff it full of steel wool...
