on holleys they have the blue gaskets between the bowl and metering block which are for the most part reusable. You can pull the carb apart numerous times to do whatever, and not have to buy a new gasket or a set of. A wonderful idea.
On the p.o.f.s. mercarb on my 3.0L in the boat the one "main" gasket between the bowl cover and body, which is all you ever really pull apart to service carb to adjust float, rejet or clean is only available in the rebuild kit at $26.
It's the typical black dark gray color paper type gasket. I've tried coating both sides with white lithium grease, in addition to having the metal surfaces clean as can be, but after time and so many heat cycles the thing ends up sticking to the metal and tearing. Anybody have any solutions?
