92 legend, 50K, has coil packs which have some carbon build-up on the electrode. car has a slightly trembly idle. can these coil packs be cleaned. the electrode is about 4 inches inside the plug cover and I can't figure out how to clean it. should I use, brake cleaner, intake manifold cleaner, use a long screwdriver and chisel it off(will take hours). I've checked the ohms and all six are perfectly within spec.
thanks.
thanks.
