So in 2013 Honda Civic went from the big spindle nut type of rear wheel bearing to the kind that has the four bolts . I have a 2013 Civic with a bad rear wheel bearing. This Civic has drum rear brakes. It will be easy to remove the 4 bolts as they are on the outside. My question is: will I be able to manipulate the bearing with the 4 bolt flanges out of the drum brake mechanism without disassembling the drum brake mechanism? I really hate messing around with drum brake mechanisms!!!
