Having issue with an Echo SRM 230. It will start and run but idles high.
I have messed with the throttle stop trying to lower it but it just cuts out. The odd thing is if you unscrew the gas cap it will idle normal but as soon as you tighten it back up it will start acting funny.
I stuck a new carb on it thinking it was the problem but it acts the same.
