Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
91 registered members (4WD, ABN_CBT_ENGR, advocate, alex16, AlienBug, 2015_PSD, 8 invisible), 1,832 guests, and 27 spiders.
Topics307,402
Posts5,310,461
Members71,843
Johnson Suzuki 225 4-stroke Engine Oil? #5428016 05/13/20 08:49 AM
I
ItsMeHank Offline OP
I
New to boat maintenance so I knew to come here first for the engine oil.
Here is the suzuki spec:
Quote
Suzuki oil meets the National Marine Manufacturer Association (NMMA) Four Cycle Water Cooled (FC-W) standards. The actual oil recommendation is: SAE or NMMA FC-W 10W-40 (operating in temps from 14 degrees to over 100 degrees F) or 10W-30 (operating in temps from -4 degrees to 86 degrees F) API or NMMA FC-W Classification SE,SF,SG,SJ. For temps below -15 degrees F use SAE or NMMA FC-W 5W-30.
I'm seeing some discussion about Diesel oil. Any recommendations there? I'm in the South Carolina so want to cover the high temp range. I also run the full rpm range - up to 6000rpm every now and then so want something that isn't going to foam. Any knowledge appreciated. I like buying my oil from Walmart but I don't want to cheap out if it's a bad idea.
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: ItsMeHank] #5428025 05/13/20 09:00 AM
CT8 Offline
Diesel oil is what the engines use for fuel...The HDEO oil are more resistant to foaming than passenger car oil since the advent of Caterpillar's introduction of the Heui fuel injection systems. I doubt foaming is an issue with any of todays oils from a quality bottler.
2015 F150 2.7
2018 F350 6.2
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: CT8] #5428068 05/13/20 09:42 AM
I
I
First off, thank you - but what do you mean here?
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: ItsMeHank] #5428087 05/13/20 09:57 AM
stockrex Offline
Is it still under warranty?
I have a merc 95 hp and I use the marine rated full synthetic mystik oil.
cheap, synthetic and marine rated, what else can a man ask ;-)
if you idle a lot, change often, mine makes oil when I idle or troll at idle (michigan salmon fishing for ya)
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: ItsMeHank] #5428092 05/13/20 10:05 AM
Snagglefoot Offline
I would stick with a NMMA FCW four stroke oil. Here is a list:
http://www.nmma.ca/assets/cabinets/Cabinet456/2017%20FC-W%20List.pdf
If you want the job done right......do it yourself.
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: ItsMeHank] #5428152 05/13/20 10:54 AM
P
PontiacHO Offline
P
West Marine 10W40 is what I used in my Suzuki.
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: ItsMeHank] #5428435 05/13/20 05:11 PM
T
totegoat Offline
T
Used this in my Johnson/Suzuki 115, OMC Synthetic 4-stroke outboard oil allows you to go 200 hours between changes.
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: ItsMeHank] #5428688 05/13/20 11:23 PM
W
whosmatt Offline
W
It's an unhelpful reply. Diesel oil can mean fuel, but in this context you clearly mean motor oil meant for use in diesel engines. Back to your question, the mfg recommendations in your first post suggest using Suzuki oil but what it boils down to is that any modern passenger car motor oil that is the correct weight is fine. The "s" ratings (API Service) are pretty lenient. The current standard is "SN" and if "SJ" is sufficient "SN" is fine. So if you want to buy at Walmart, I'd do the Supertech full synthetic if you can find it in the correct weight. Regarding the diesel oil - 15W-40 is a common weight for motor oils specifically marketed for diesel engines, such as Shell Rotella. I'd just run a gasoline passenger car oil personally.
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: ItsMeHank] #5428745 05/14/20 06:10 AM
gotnogunk Offline
Agree with STOCKREX- Mystic if you can find it, if not a good HDEO
2018 Cadillac XTS 3.6
2014 Ford F150 3.7 supercrew
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: ItsMeHank] #5428791 05/14/20 07:29 AM
4WD Online Confused
Online Confused
A couple years back a Suzuki mechanic posted a warning over oil foaming. He demonstrated with a twin engine offshore boat that after a long run with one engine using PCMO and one on NMMA oil … you could actually pull dipsticks and see for yourself. Unfortunately he did not do the test with HDEO … he left one with what the client used and one FC-W.
This would indicate you could run WOT and check the stick on whatever oil you go with. Think either is fine, and buying HDEO for such a good price can be conducive towards more frequent changes.
I only buy two quarts a year, so just stick with FC-W at this stage …
Re: Johnson Suzuki 225 4-stroke Engine Oil? [Re: gotnogunk] #5428793 05/14/20 07:31 AM
4WD Online Confused
Online Confused
I have posted Mystik JT4 specs here before … Looks solid … even a really good Noack.
