- Joined
- Sep 26, 2010
- Messages
- 9,807
This may seem like a silly question, but the forest and the trees have merged.
The rear axle ring gear rotates towards the front of the vehicle, picking up oil from the sump and slinging it over the top of the pinion gear from the top of the ring gear.
Since the from axle is installed "backwards" does its ring gear pick up oil from the sump and sling it under the bottom of the pinion gear from the bottom of the ring gear OR does it rotate the same as the rear axle (towards the front of the vehicle)?
Try not to laugh too hard when reading/answering.
