Originally Posted by dlundblad
Originally Posted by DallasTexas
Originally Posted by JHZR2
AGM batteries vent at ~1% of other non-sealed batteries. The AGM batteries have a glass mat to wick electrolyte. They are also called Valve-Regulated Lead Acid (VRLA), because they are "sealed" with a valve that opens if and only if the internal pressure (from overvoltages due to high rate/high voltage charging, electrolyzing the water in there) goes too high. Otherwise it stays shut to allow the H2/O2 to recombine.
OP, Id recommend considering an AGM battery if you are set on having it be "sealed". Not entirely sure why it matters in many/most applications, but that's your call.
All AGM I have encountered are vented to exterior of cabin.
Do they not leak then? My wife's Volvo is setup similar. The battery is in the trunk and is vented by a tube that runs below and out the car.
I don't remember it leaking, but the battery is way too big for my needs. H11 I believe.
Got around 8 years out of the last battery IIRC.
You sure that H11 is right? Mine is an H8 and that's a big battery. Can't really find an H11 automotive battery. 12 years no leak. Even killed it once, had to bring it inside to charge it. That was heavy, carrying almost 60 pounds a few hundred feet. Just awkward to carry, I smarted up and used a two wheeler to carry it back.
