Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
Ac rebates horrible to deal with
by cknight49090 - 07/01/20 01:58 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
27 registered members (alchargo, carlprop, Deontologist, ChristianBerg, bulwnkl, 2009Caraman, 2 invisible), 891 guests, and 32 spiders.
Topics307,387
Posts5,309,601
Members71,821
Diagnosing AC Failure 2007 Honda Fit #5419249 05/02/20 03:13 PM
L
ltslimjim Offline OP
L
Vehicle: 2007 Honda Fit Sport AT
Hey guys, it’s been a while but I’m back with a new AC problem. A couple of years ago the relay for the compressor went bad and replacing that got it back working.
Now, the AC just completely failed while driving the other day.
The compressor pulley spin w/ belt, but clutch does not attempt to engage.
So far:
Jumpering the relay does not activate the coil. While jumpered, there is no magnetism...or a very very weak one at best. A multimeter revealed battery voltage to the connector.
However, the clutch will not turn by hand despite AC being off.
Is this a seized compressor and broken coil?
Would a low charge, failed switch, or thermal protector prevent the clutch from turning by hand while engine is off?
Obviously, I can’t get pressure readings while the system won’t run.
I am limited on diagnostic tools at the moment but also don’t want to just throw parts at it. I’m not aware if this pressure switch is the kind that will self-seal.
I may need a mechanic but seeking advice first.
Uploading photos of clutch plate removed:
66385180-4B65-472C-92A1-A1DFFCD534FB.jpegE4242687-1821-4787-B25C-0509EF80C2A5.jpegCA5A2832-C589-4025-87AE-42881B0C3659.jpeg
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
Re: Diagnosing AC Failure 2007 Honda Fit [Re: ltslimjim] #5419264 05/02/20 03:39 PM
L
L
Also tested:
Resistance on pressure switch (4 ohms)
Continuity from battery to AC relay (good)
Continuity from relay to compressor connection (good)
Rotation on compressor (could not rotate by hand or with a tool)
Re: Diagnosing AC Failure 2007 Honda Fit [Re: ltslimjim] #5419266 05/02/20 03:40 PM
Chris142 Offline
The compressor seized. Overheated the coil until it got an open circuit. I see it daily.
Time for a complete rebuild including a condenser.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Diagnosing AC Failure 2007 Honda Fit [Re: Chris142] #5419287 05/02/20 04:10 PM
L
L
Figured. Well, thanks for confirming.
Are there any parts I can skip? Which parts are essential other than what you mentioned?
I would need a shop to do the job obviously. I used one for years that lets me use my own parts but this is my first AC repair with them. I would hope they don’t have to dig into the dash for evap parts. Trying to minimize some of the labor without compromising new parts.
So, new condenser and the receiver/drier at minimum? Thinking of a Denso condenser and a Nissen compressor. RA has them both.
By the way, the existing condenser already has missing fins. Come to find out, they are very susceptible to any road debris as Honda didn’t make these with a guard/screen inside the grill.
Re: Diagnosing AC Failure 2007 Honda Fit [Re: ltslimjim] #5419323 05/02/20 05:44 PM
Chris142 Offline
There are no short cuts in AC repair. Any leftover debris will go right into the compressor and destroy the new one. Now you have 2 failures to clean up.
Re: Diagnosing AC Failure 2007 Honda Fit [Re: Chris142] #5419324 05/02/20 05:48 PM
L
L
Is there a method to flushing the system of debris properly?
Re: Diagnosing AC Failure 2007 Honda Fit [Re: ltslimjim] #5419356 05/02/20 06:42 PM
Chris142 Offline
Basically open every connection. Don't forget to remove the expansion valve as you can not flush through it.
Re: Diagnosing AC Failure 2007 Honda Fit [Re: ltslimjim] #5419502 05/02/20 10:43 PM
A
antonmnster Offline
A
And don't make the mistake I did and not flush the lines after changing everything. The compressor debris immediately plugged up the new condenser.
2007 BMW 335i n54 218,000 miles, lubricated by whatever is on sale
