Originally Posted by slacktide_bitog
Will the longer 4386 fit? Use the 4386 next time, and if that still doesn't do the trick, use the K&N filters with the nut on the end
I have often used the 4386 sized filter but not this time because I got them at an RA clearance..I've read that I could use a 3614 or even a 3600 from my Fords on the Corolla but I've never done it. I won't need the filters with the nut on top because I plan to oil the gasket better and hand tighten only in the future (Sayjacs good advice).....The thing that surprised me was that the fluted end was the strongest part of the filter (according to the guy at NT)....I was trying to get a bite on the filter as close to the base plate as possible...had I tried the fluted end...I may have gotten it off with the HF filter pliers.
