I know many, self included, will take a short drive or idle the engine prior to an oil change so that the oil will drain more quickly. I have a magnetic heater that goes on the oil pan to warm the oil during the winter. Wondering if I can use this to warm the oil prior to changing it? Only concern is warming up the oil filter prior to changing as a cold filter might be more difficult to remove. Guess I will find out.
