Forums Migration
Please read this thread
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Swimming Pool Chlorination
by Al - 07/08/20 02:30 PM
Purolator Boss
by RazorsEdge - 07/08/20 02:01 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
45 registered members (BoiseBound, blufeb95, Alex38, boom10ful, BlakeB, AITG, 3 invisible), 1,029 guests, and 29 spiders.
Topics307,625
Posts5,314,459
Members71,888
installing garage LED shop light help needed #5395700 04/06/20 05:20 PM
F
FirstNissan Offline OP
F
Hi, I hope everyone is staying healthy and safe.
I recently bought a few 4-ft LED shop lights for my garage. they come with chains to suspend them. my garage has drywall on the ceilings. I was wondering if anyone had suggestions on how to mount these. I've never mounted anything to ceilings so I'm not sure if a regular stud finder would work? are there any drywall anchors that I can use that would make my life easier, the lights themselves each way about seven or eight pounds tops. thank you
2017 Toyota Sienna
2019 Toyota Camry
Re: installing garage LED shop light help needed [Re: FirstNissan] #5395708 04/06/20 05:29 PM
J
JustinH Offline
J
I used little screw in type hooks to mount my last set. Drill a pilot hole and try to hit at least a few studs.
Or you can use a toggle bolt style hook.
'16 Ford Escape
'11 Scion XB
Re: installing garage LED shop light help needed [Re: FirstNissan] #5395709 04/06/20 05:29 PM
B
bullwinkle Offline
B
I would use a stud finder & look for joists/rafters, might even be able to use one of those telescoping ceiling fan junction box with supports. Or wear a hard hat whenever you're working on something! crazy
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: installing garage LED shop light help needed [Re: FirstNissan] #5395711 04/06/20 05:30 PM
2015_PSD Offline
A stud finder should work and the drywall in **most** garages is not that "finished" so you should be able to find dimples in the drywall where they nailed/screwed it into the studs.I used eye hooks in my FIL shop to attach the chains.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Kendall GT-1 Max + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: installing garage LED shop light help needed [Re: FirstNissan] #5395712 04/06/20 05:31 PM
Rat407 Offline
If you are going to be using the pull chain to turn on and off then make sure you mount in a stud. If not then the drywall anchors would work just fine I would think.
2014 Cruze Diesel 5w-30 AMSOIL
Re: installing garage LED shop light help needed [Re: FirstNissan] #5395718 04/06/20 05:44 PM
J
JC1 Offline
J
I would look for studs with a stud finder. If there are removable covers remove them and secure the cases with washers and screws or pan head screws. I'm sure you garage door vibration will cause the fixtures to move a slight bit.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: installing garage LED shop light help needed [Re: FirstNissan] #5395838 04/06/20 07:46 PM
Snagglefoot Offline
I agree with the stud finder and finding the layout of the rafters. Once you get a good feel on how everything is laid out you can wire them up. Is there an attic? If not you can use metal clad cables running along the ceiling to keep it legal.
If you want the job done right......do it yourself.
Re: installing garage LED shop light help needed [Re: FirstNissan] #5395875 04/06/20 08:48 PM
J
JMJNet Offline
J
  • 2017 Toyota Sienna
Re: installing garage LED shop light help needed [Re: FirstNissan] #5396006 04/07/20 12:00 AM
BlueOvalFitter Offline
This is what I would use.
2007 F150, XL, 4.2 V6
5W30 Amsoil Signature Series Oil
NAPA GOLD 1516 Oil Filter
Re: installing garage LED shop light help needed [Re: FirstNissan] #5396789 04/07/20 07:51 PM
J
JTK Online Content
Online Content
J
I dunno if you can get the housings apart- probably not, but I've flush-mounted some shop light fixtures in the past depending on the ceiling height and application. Just used screws and fender washers.
Like said, these 4ft LED fixtures tend to be so light weight, I wouldn't sweat not being able to find studs and use the winged toggle bolts like pic'd above if need be.
You're going to love those LED lights.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
