Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
33 registered members (ArrestMeRedZ, daves87rs, AndyB, ctechbob, bbhero, 830Lee), 1,338 guests, and 52 spiders.
Topics306,109
Posts5,286,659
Members71,586
Washer stuck between the water pump housing and timing chain cover. #5387463 03/27/20 10:15 PM
M
motor_oil_madman Offline OP
M
Had a friend change out the thermostat housing gasket on my brand new boat engine that was leaking and he dropped both of the washers when pulling it off. One landed in the bilge which i retreived, the other where I described so in the title. He said it was fine and wont hurt anything after I tried getting it out for probably 10 minutes. I might take compressed air and shove that in it. It just drives me crazy. He just went and found another same sized washer and put her back together. Am i being paranoid? My only concern is that it comes loose and gets jammed into a pulley or something when running.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Washer stuck between the water pump housing and timing chain cover. [Re: motor_oil_madman] #5387464 03/27/20 10:17 PM
Chris142 Offline
Your being paranoid.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Washer stuck between the water pump housing and timing chain cover. [Re: motor_oil_madman] #5387470 03/27/20 10:35 PM
Z
zrxkawboy Offline
Z
It won't hurt anything.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Washer stuck between the water pump housing and timing chain cover. [Re: motor_oil_madman] #5387474 03/27/20 10:40 PM
T
Trav Offline
T
It isn't down with the timing chain is it? That would cause me some concern but if just between an external cover forget it.
Re: Washer stuck between the water pump housing and timing chain cover. [Re: motor_oil_madman] #5387476 03/27/20 10:44 PM
O
oldhp Offline
O
Small block Chevy? Try a slim Jim unlock tool. It's thin and pretty ridged. You should be able to pop it up with that.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Washer stuck between the water pump housing and timing chain cover. [Re: Trav] #5387481 03/27/20 10:55 PM
M
M
Between the cover. The timing chain cover that is.
Re: Washer stuck between the water pump housing and timing chain cover. [Re: motor_oil_madman] #5387482 03/27/20 11:02 PM
Driz Offline
Magnetic pick up tool . The kind with the tiny magnet on an telescoping arm or claw type as mentioned. Get a good one it will last till you lose it. The cheapies are not so great and fall apart fairly easy. I can’t see much worrying about it though really. It won’t hurt anything and will probably end up in the bilge eventually anyway😎
Re: Washer stuck between the water pump housing and timing chain cover. [Re: motor_oil_madman] #5387516 03/28/20 12:40 AM
B
Blkstanger Offline
B
Get help for your OCD.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 75,000mi. Castrol Edge EP 5w30 Fram Ultra.
Re: Washer stuck between the water pump housing and timing chain cover. [Re: Driz] #5387521 03/28/20 01:22 AM
R
rubberchicken Offline
R
This- magnetic pickup tool, or a claw-type tool.
https://www.amazon.com/X-Long-Flex-...ol+grabber&qid=1585376477&sr=8-5
This combines both types into one tool
https://www.amazon.com/VASTOOLS-Fle...l+grabber&qid=1585376507&sr=8-13
Re: Washer stuck between the water pump housing and timing chain cover. [Re: motor_oil_madman] #5387546 03/28/20 04:25 AM
PimTac Offline
Find a old hacksaw blade and get it out.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Washer stuck between the water pump housing and timing chain cover. [Re: Blkstanger] #5387718 03/28/20 09:24 AM
M
M
It's determination. There is a difference. I'll get that washer out at some point and it will go back on. It's cadium plated so it's not going to rust.
Re: Washer stuck between the water pump housing and timing chain cover. [Re: motor_oil_madman] #5389128 03/30/20 07:04 AM
G
Gebo Offline
G
I'm with you!
Sorta like me trying to get the plastic transmission cover back on my Lexus. There's that one 10mm that I can barely reach. I keep going
until I get it. I go till my hand cramps. Leave and come back. IT DOES GET ON.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Washer stuck between the water pump housing and timing chain cover. [Re: motor_oil_madman] #5389401 03/30/20 12:22 PM
O
Olas Offline
O
Do you have a strong magnet and a fishing pole? You might get it out that way..
If you have some spare time at the moment like so many of us do, maybe get the tools out and you’ll be happy that you did it right.
I’m not familiar with the engine or the boat so might be wrong but if there is any possibility of it getting into your timing gear/belt/chain then you should probably go get it out of there ASAP.
