2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
Twilight Zone
by 2015_PSD - 04/04/20 03:57 PM
Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
89 registered members (55hambone, ammolab, 4.8 Silverado, another Todd, Andreeas1978, 2015_PSD, 5 invisible), 2,658 guests, and 17 spiders.
Topics303,591
Posts5,237,911
Members71,094
Initial Oil Change #5386376 03/26/20 05:15 PM
P
Plimbob Offline OP
P
I bought a 2017 Tahoe 5.3L that was a theft with 77,000 miles on it. Having no knowledge of any maintenance that has been done. I was going to change the oil and filter and run it for 500 miles and change it again. What oil do you all suggest would be the best for higher detergent content.
Re: Initial Oil Change [Re: Plimbob] #5386381 03/26/20 05:18 PM
P
patfan Offline
P
Pennzoil platinum
Re: Initial Oil Change [Re: Plimbob] #5386384 03/26/20 05:19 PM
4WD Offline
Any Dexos for that short run … I’d be worried it has factory fill in the differential …
2WD or 4WD ?
Re: Initial Oil Change [Re: Plimbob] #5386392 03/26/20 05:24 PM
A
atikovi Offline
A
3 or 4 miles would be enough to mix the oil thoroughly. Change it again then if you want a fresh start.
Re: Initial Oil Change [Re: Plimbob] #5386398 03/26/20 05:30 PM
O
Oildudeny Offline
O
500 mile fill and dump, i would go with super tech or napa 5w30 dino.. wouldn't waste synthetic
Re: Initial Oil Change [Re: Plimbob] #5386404 03/26/20 05:33 PM
T
Triple_Se7en Offline
T
Check the oil dipstick at 500 miles and unless the oil is dirty black, leave it in. Odds are, it's amber brown and good-to-go for another 1K at-least.
Keep Your Pistons, Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Initial Oil Change [Re: Plimbob] #5386436 03/26/20 06:03 PM
CT8 Offline
what about the differentials, trans,transfer case and radiator?
2015 F150 2.7
2018 F350 6.2
Re: Initial Oil Change [Re: Plimbob] #5386446 03/26/20 06:14 PM
CT8 Offline
All the oils are similar.
2015 F150 2.7
2018 F350 6.2
Re: Initial Oil Change [Re: CT8] #5386451 03/26/20 06:20 PM
A
atikovi Offline
A
Well, coolant is 5 years 150,000 miles so that's a ways off.
Re: Initial Oil Change [Re: atikovi] #5386464 03/26/20 06:32 PM
P
Plimbob Offline OP
P
Sorry Guys - Its a 4WD. I was planning on the diffs & Transfer case as well.
Also, going to drain the trans and replace the filter and fluid. I was planning on using AC Delco Dex VI for that. Any other suggestions for trans fluid?
I use Valvoline trans fluid in my 07 Tahoe (289,000 miles on it) and it seems to shift fine ,etc.
Re: Initial Oil Change [Re: Oildudeny] #5386482 03/26/20 07:12 PM
V
Villalobos Offline
V
I agree with that, good inexpensive 5w30, maybe do 2 500 OCI, 3 5 quart jugs can be had for less than $50 and 2 $7 oil filters, so for less than $70, for piece of mind. I have a 2000 Suburban ready to turn 250k. I’ve maintained for 20 years on a steady diet of ACDelco 5w30 and ACDelco oil filter with 3k OCI. It’s a legendary motor.
2000 Suburban 250k
2014 MKX 100k
2015 IS250 50k
Re: Initial Oil Change [Re: Oildudeny] #5386524 03/26/20 07:56 PM
BlueOvalFitter Offline
Or, PYB. thumbsup
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Initial Oil Change [Re: Triple_Se7en] #5386709 03/27/20 02:38 AM
L
Linctex Offline
L
I agree.
Don't change the oil unless you see it get dark.
IT WILL - - - - if the engine is really dirty inside.
Make note of the mileage at the point this occurs.
Just use any cheap oil to accomplish this task.
