Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
104 registered members (762fermeandyou, 2015_PSD, ArrestMeRedZ, 2004tdigls, 1978elcamino, 10 invisible), 2,678 guests, and 59 spiders.
Topics305,903
Posts5,282,478
Members71,535
Page 2 of 2 1 2
Re: Treated fence stain or paint? [Re: dja4260] #5385709 03/25/20 07:01 PM
Dave9 Offline
It depends on your goal. If you want it to age gracefully and can accept a weathered look, then stain it and let it go longer.
If you want the wood to last the longest, use an oil based high solids paint which blocks MUCH more UV. It will need repainted more often to look pretty, but will also have more preservation from the oil in the paint. Hint: If you pick a color similar to the underlying wood color, it will look acceptable longer.
Re: Treated fence stain or paint? [Re: dja4260] #5385733 03/25/20 07:37 PM
G
gman2304 Offline
G
Calling Demarpaint!
Re: Treated fence stain or paint? [Re: dja4260] #5385803 03/25/20 09:02 PM
Marco620 Offline
Pine is a soft wood and usually does better with water based products.
15' Civic r18, 333,333 mi M1 0w30/5w30 & LG Biotech,Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind, and anything vegan.
Re: Treated fence stain or paint? [Re: dja4260] #5385958 03/26/20 07:39 AM
dja4260 Offline OP
Thank you for the feedback. I understand that nothing is permanent. I'd be fine having the fence redone every 4-5 years. Keep the advice coming!
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
Re: Treated fence stain or paint? [Re: dja4260] #5385973 03/26/20 08:06 AM
Astro14 Offline
Two basic choices: film finish (paint) and penetrating finish (stain)
Film finishes have more even color, protect wood better, but require more prep for good adhesion and require recoating periodically.
Penetrating finishes can be absorbed unevenly by pine, resulting in color blotches, and don’t protect wood as well, but they don’t chip or flake and are easier to retouch.
Go with a stain.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Treated fence stain or paint? [Re: dja4260] #5385975 03/26/20 08:09 AM
doitmyself Offline
I disagree that water based stain is better for pine (or much of anything). Oil base penetrates and protects better. But, the market is changing and moving towards low VOC water based products more and more. And, the marketing indicates that water based products are improving. I recommend not using anything that forms a film.
The site below seemed to have some of the best stain info, but they have changed it and I can no longer find extensive reviews of most of the stain products (i.e., Cabots, Penofin, Olympic, etc.) They seem to just list their best picks. Correct me if you find the other products reviewed like they used to do. But, it is still a good site to study and glean information.
https://www.deckstainhelp.com/
Re: Treated fence stain or paint? [Re: doitmyself] #5385996 03/26/20 08:48 AM
dja4260 Offline OP
Great site/resource! Thank you
1997 HD Sportster
Re: Treated fence stain or paint? [Re: dja4260] #5386068 03/26/20 10:10 AM
Davejam Offline
That site seems to recommend TWP 100 line stain. Any comments on that versus Penofin?
Page 2 of 2 1 2
