Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
94 registered members (Atrocious, B34R, 97prizm, ABerns, amblerman, 8 invisible), 2,586 guests, and 26 spiders.
Topics305,903
Posts5,282,460
Members71,535
Battery Shot? #5385366 03/25/20 11:39 AM
coopns Offline OP
My second year with a used Huqavarna tractor. husqvarna yth150
Just trying to fire it up/change oil/plug for spring. Replaced spark plug.
Trickle charged overnight because it wouldn't start. Started. Ran for 5 mins. Tried to start 30 mins. later and wouldn't start and not much cranking
just died. Charged it again overnight last night and shot some starter fluid in the air filter area (sorry, is that the right place) and it started.
Sounds like a new battery does it? Guessing 3 years old battery. If it is battery, any recommendations?
Coop
Re: Battery Shot? [Re: coopns] #5385372 03/25/20 11:42 AM
Quattro Pete Offline
Originally Posted by coopns
Tickle charged overnight
Did it giggle? smile
What is the size of the battery? I think Yuasa is a well respected brand in smaller/OPE/motorcyle type batteries.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Battery Shot? [Re: coopns] #5385381 03/25/20 11:55 AM
spasm3 Offline
Probably, but need to know the voltage after charging. Make sure they are fully charged before winter. I unhook mine to eliminate any draw. Sometimes i put it on a float charger in my garage.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Battery Shot? [Re: coopns] #5385382 03/25/20 11:55 AM
stroked93 Offline
give it 30 minutes with 10 or 15 amps. if that doesn't do it its probably bad.
Re: Battery Shot? [Re: coopns] #5385434 03/25/20 12:57 PM
Donald Offline
Most do not last too long if not on a battery maintainer over the winter.
NAPA should be an OK place for a battery. Check the date of manufacture. I would say one manufactured in 2020. HomeDepot probably has them also. You just don't want one that has been on the shelf since last summer.
Is a lawn tractor battery essential? May need to buy some Twinkies on same trip to make it an essential trip.
2015 Ford F-250 w/Powerstroke
Re: Battery Shot? [Re: coopns] #5385439 03/25/20 01:04 PM
M
mk378 Offline
M
The Briggs V-twin engine will act like the battery is weak when the valves get loose and the compression release feature stops working.
Measure voltage at the battery while trying to start, or load test it.
Wal-Mart usually sells the standard lawn tractor battery size in three grades. They don't last very long in any case so no reason to pay more.
Re: Battery Shot? [Re: coopns] #5385472 03/25/20 02:00 PM
samven Offline
I hate to say it but 3 years is about it for these cheap U1 batteries. I always buy the highest CCA battery I can find but put a cap of $39 on it. I have tried the more expensive ones but if they lasted any longer it was not enough to justify the cost. I take mine out after the last cut of the season and bring it into the garage and charge it up and then check it and top it up every month or so. By the third or fourth season I am having to boost them to get the tractor started if it gets cold out. I thought about getting a wheel chair battery as they are Deep Cycle U1's and seem to be higher quality but they cost 2x-3x what a Walmart 300 CCA costs. Just make sure they are strapped down tight because the shock of bouncing around will kill them the first year.
Re: Battery Shot? [Re: mk378] #5385474 03/25/20 02:02 PM
B
blufeb95 Online Content
Online Content
B
With the automotive center being closed can you buy batteries at Wal-Mart right now?
Re: Battery Shot? [Re: coopns] #5385479 03/25/20 02:07 PM
G
gman2304 Offline
G
After these small batteries discharge, they’re typically shot, plus yours is 3 years old. Batteries plus has a Duracell to fit your Husky, 300 cca with a $10 rebate 6 month free exchange warranty for $47.00. For less than $40 after rebate, this sounds like a good deal.
Re: Battery Shot? [Re: coopns] #5385581 03/25/20 04:32 PM
T
Tdbo Offline
T
These batteries are typically poor quality across the board.
There is really no advantage to buying an expensive one.
I have had a $46. John Deere battery last one year, while getting multiple years out of a $20 cheapo.
NAPA has one on sale this month for $23.99.
Many times this time of year, farm stores run deals w/rebates. The last I bought was at Rural King for $12.99 w/ a MIR.
2012 Honda Accord LX-P 103K
2008 Ford Mustang Pony Package Convertible 18K
2006 Honda Odyssey EX-L 77K
2003 Ford Ranger 3.0 Supercab 127K
Re: Battery Shot? [Re: blufeb95] #5385688 03/25/20 06:38 PM
Dave9 Offline
Depends on how your (local store) automotive center is set up. The one I go to, you can still walk into that area and they have the batteries on the rack, so you can grab it and checkout at the front registers, 24/7. If there is a core charge, you have to convince the cashier that they're supposed to take your old battery (leave it sit till a grunt can come get it) and give you a credit there. They can do that, have for me.
I get about 6 years out of the battery for my riding mower. It gets charged up around the end of November, then topped off in Feb or Mar, then voltage tested before first mowing of the year to be sure it won't discharge too deeply on that first start of the season. I used to leave a trickle charger on it all winter, then needed to use the charger for something else (didn't feel like buying or making more) and never looked back. IMO the main thing is just don't let it discharge TOO much then let it sit in that state. An otherwise healthy lead acid battery should have no problem sitting for ~3 months if there's no parasitic drain on it.
Re: Battery Shot? [Re: coopns] #5385690 03/25/20 06:41 PM
A
Astro_Guy Offline
A
I've had a similar experience with my John Deere. The original battery went four seasons and I was able to get it to start once at the beginning of season five after a few hours on the charger. It ran fine that day but refused to start after any amount of charging after that. The original battery was rated at 190 CCA. I replaced that with a 230 CCA battery from Walmart for $25. Now it is season six for the machine and season two for the battery, and it is starting up just fine. The advice of buying the highest CCA rated battery in class is controversial in my book. Cold Cranking Amps (CCA) are determined by the surface area of the plates in the battery. The only way to increase this within the confines of a specific battery size is to make them thinner. Thinner plates may wear out faster.
An undersized battery may wear out faster because it has to work harder to get the job done. An oversize battery might wear out faster due to the thinner plates. Think of this as a Goldilocks problem and find the battery with the CCA rating that is just right for your application.
Re: Battery Shot? [Re: Astro_Guy] #5385702 03/25/20 06:48 PM
Dave9 Offline
No that is not true. Higher CCA batteries of the same type (start vs start/run vs deep cycle vs vented vs sealed vs AGM, etc) have more lead in them, and tend to last longer not shorter. It is definitely not a matter of using thinner plates that wear out faster.
However if you're using equipment that only needs to start in warm weather, then you might consider getting a deep cycle battery instead, then you get substantially thicker plates with less surface area. If the ignition system is in poor shape you may not have enough CCA, so this is not a universal solution.
Further, if your battery is "oversized" and that means it has a higher Ah capacity, that means it discharges less with each use-event which also promotes longer life.
Re: Battery Shot? [Re: Dave9] #5385715 03/25/20 07:07 PM
A
Astro_Guy Offline
A
I respectfully disagree. Ah capacity is determined by the mass of the reactants, meaning lead and acid. CCA capacity is determined by the available surface area of the reactants. This is why deep cycle batteries have lower CCA ratings than typical starting batteries. Deep cycle batteries have thicker plates with greater spacing. This allows them to discharge further and then recharge with less potential for bridging the plates during the recharge cycle.
The best of all worlds in terms of lead-acid technology are the AGM batteries, but I digress.
Re: Battery Shot? [Re: coopns] #5385899 03/26/20 04:50 AM
L
Lubener Offline
L
If a new battery doesn't fix it, may be time to adust valve clearances.
The "thinking" man's friend.
