New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
91 registered members (Al, AlienBug, ajchien, 14Accent, 97trophy, 55hambone, 10 invisible), 1,541 guests, and 21 spiders.
Topics307,426
Posts5,310,803
Members71,843
Hydraulic Fluid Change Question #5384040 03/23/20 08:05 PM
L
lancerplayer Offline OP
L
I have a new to me John Deere Z445 zero turn mower. I would like to do some basic maintenance on it before the mowing season. I plan to change the engine oil and filter, air filter, fuel filter, spark plugs, and transaxle hydraulic fluid.
Fluid spec: John Deere Low Viscosity HY-GARD® (J20D)
My question is: following the manufacturer's procedure, will I have to be concerned with any air getting into the hydraulic system? Will I have to purge the system?
1. Park machine safely on a level surface.
2. Raise operator’s seat, and clean area around reservoir cap. Remove cap.
3. Clean area around hydraulic oil filter.
4. Place drain pan with at least a 9.9 L (10.5 qt) capacity under hydraulic oil filter, turn filter counterclockwise to remove and allow oil to drain completely.
5. Apply a film of clean oil on gasket of new filter.
6. Install filter. Turn filter clockwise until gasket makes contact with the mounting surface. Tighten 1/2 to 3/4 turn after gasket contact.
NOTE: Reservoir capacity is approximately 8.5 L (9 qt). Total system capacity with filter is approximately 9.9 L (10.5 qt).
7. Fill oil reservoir with approximately 8.5 L (9 qt) of oil.
8. Install reservoir cap.
9. Start engine.
10. Move throttle lever to the 3/4 fast idle position.
11. Unlock park brake.
12. Run engine in full forward position for five minutes and then cycle motion control levers forward and rearward several times. Check for leaks around filter.
13. Stop the engine. Check oil level in reservoir. Add oil as necessary.
Re: Hydraulic Fluid Change Question [Re: lancerplayer] #5384070 03/23/20 08:52 PM
samven Offline
That is their purge method. The running for 5 min in forward just heats up the hydraulic fluid to normal operating temps then the cycle of forward reverse purges any air in the system. On my tractor after a fluid change I do similar. Idle system for 5 min then run tractor in forward for several min then cycle the front end loader up and down bucket in and out looking for jerky movement. Run PTO and lift and lower mid deck several times.
Re: Hydraulic Fluid Change Question [Re: lancerplayer] #5384710 03/24/20 03:49 PM
J
JTK Offline
J
Not sure what drive system this JD uses, but on most of them, after the refill, you pull the bypass lever on the drive, start the engine and cycle the controls forward-reverse a few times to purge the air out. If it's a separate hydraulic pump and motor drive, air will typically work it's way through the system.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
