Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
106 registered members (2165, 87sammy, 830Lee, 2010Civic, 99cyclone, 12 invisible), 2,283 guests, and 25 spiders.
Topics306,040
Posts5,286,224
Members71,593
Hydraulic Fluid Change Question #5384040 03/23/20 08:05 PM
L
lancerplayer Offline OP
L
I have a new to me John Deere Z445 zero turn mower. I would like to do some basic maintenance on it before the mowing season. I plan to change the engine oil and filter, air filter, fuel filter, spark plugs, and transaxle hydraulic fluid.
Fluid spec: John Deere Low Viscosity HY-GARD® (J20D)
My question is: following the manufacturer's procedure, will I have to be concerned with any air getting into the hydraulic system? Will I have to purge the system?
1. Park machine safely on a level surface.
2. Raise operator’s seat, and clean area around reservoir cap. Remove cap.
3. Clean area around hydraulic oil filter.
4. Place drain pan with at least a 9.9 L (10.5 qt) capacity under hydraulic oil filter, turn filter counterclockwise to remove and allow oil to drain completely.
5. Apply a film of clean oil on gasket of new filter.
6. Install filter. Turn filter clockwise until gasket makes contact with the mounting surface. Tighten 1/2 to 3/4 turn after gasket contact.
NOTE: Reservoir capacity is approximately 8.5 L (9 qt). Total system capacity with filter is approximately 9.9 L (10.5 qt).
7. Fill oil reservoir with approximately 8.5 L (9 qt) of oil.
8. Install reservoir cap.
9. Start engine.
10. Move throttle lever to the 3/4 fast idle position.
11. Unlock park brake.
12. Run engine in full forward position for five minutes and then cycle motion control levers forward and rearward several times. Check for leaks around filter.
13. Stop the engine. Check oil level in reservoir. Add oil as necessary.
Re: Hydraulic Fluid Change Question [Re: lancerplayer] #5384070 03/23/20 08:52 PM
samven Offline
That is their purge method. The running for 5 min in forward just heats up the hydraulic fluid to normal operating temps then the cycle of forward reverse purges any air in the system. On my tractor after a fluid change I do similar. Idle system for 5 min then run tractor in forward for several min then cycle the front end loader up and down bucket in and out looking for jerky movement. Run PTO and lift and lower mid deck several times.
Re: Hydraulic Fluid Change Question [Re: lancerplayer] #5384710 03/24/20 03:49 PM
J
JTK Offline
J
Not sure what drive system this JD uses, but on most of them, after the refill, you pull the bypass lever on the drive, start the engine and cycle the controls forward-reverse a few times to purge the air out. If it's a separate hydraulic pump and motor drive, air will typically work it's way through the system.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
